Any tips on changing the rear 3 spark plugs and wires. Can't figure out how to get to them?
Mar 14, 2010 at 9:17 PM
CARADIODOC
CERTIFIED EXPERT
Gotta reach up from behind the engine, underneath. Can be hard to do if it isn't on a hoist.
The passenger side plug looks like it will be impossible to reach because of the alternator bracket in the way, but a 3" long extension on a 3/8" drive ratchet works nicely. The hardest part is actually tugging the spark plug wire off.
caradiodoc
Mar 14, 2010 at 9:29 PM
RACEFAN966
CERTIFIED EXPERT
Which V6?? With the 3.3 you will need to remove the upper plenum so a gasket is in need if its a 3.8 its best to do on a lift and reach from underneath
