Engine Cooling problem
1993 Dodge Caravan 6 cyl Two Wheel Drive Automatic 145k miles
I recently had my Grand caravan overheat and blow the radiator. I replaced it and when doing my checks found the radiator fan would not turn on when the engine heat began to rise. I swapped relays( assuming I got the right ones) and still nothing. I jumpered the wiring harness straight to the battery positve and negative terminals and the fan started spinning with ease. Any idea what it can be. I am waiting for the engine to cool then I will only jump the postive side of the fan harness to ensure I am getting a good ground to the fan motor. If your have any other ideas I would greatly apprecaite the assistance.
Oct 22, 2010 at 3:21 AM
