HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Dodge
Caravan
Steering
Column
Replace/Remove
1993 Dodge Caravan
NATIVECHIK4
MEMBER
1993 DODGE CARAVAN
1993 Dodge Caravan 121000 miles
the whole steering column was replaced and second question was could it be the relay switch?
Tuesday, February 26th, 2008 AT 10:21 PM
BMRFIXIT
MECHANIC
I’m sorry but I can make sense of your question
can you elaborate
Tuesday, February 26th, 2008 AT 10:35 PM
Please
login
or
register
to post a reply.
Related Steering Column Replace/Remove Content
1999 Dodge Caravan Possible Steering Column Issues
My Caravan Has A Lot Of Miles But Seems To Keep Going. Last Summer It Started Having Problems With Cam Position Sensor(changed Twice)...
Asked by
jimreaper
1 ANSWER
1999
DODGE CARAVAN
1993 Dodge Caravan Power Steering Woes
After 204k Miles, I Decided To Rebuild The Front End On My 1993 Dodge Grand Caravan, And Replaced Just About Everything I Could: Tie Rod...
Asked by
ShadowAlmighty
1993
DODGE CARAVAN
1993 Dodge Caravan
1993 Dodge Caravan 120000 Miles Put A Different Steering Wheel Column And The Wipers And Radio Dont Work And Windows Dont Roll Down...
Asked by
nativechik4
1 ANSWER
1993
DODGE CARAVAN
Steering Problem 1993 Dodge Caravan 6 Cyl Front Wheel Drive Automatic I Stupidly (probably Because I Was Drunk) Added Tranny Fluid...
Asked by
LT56
1 ANSWER
1993
DODGE CARAVAN
Power Steering Problems?
When It Locks Up It Doesn't Stall, Usally At Low Rpm, You Can Shut It Off Start It Back Up And Its Fine. This Only Happens When Its...
Asked by
cripps
11 IMAGES
2010
DODGE CARAVAN
VIEW MORE
Steering Wheel Removal
Tie Rod End Replacement
Power Steering Pump Pulley Removal
