1990 Dodge Caravan
JEFF MCCOURT
  • 1990 DODGE CARAVAN
  • 6 CYL
  • FWD
  • 208,000 MILES
I have a 1990 Caravan with 208,000 miles so I don't want to put too much money into it. Still, driving without heat in Minnesota in February is NOT a good idea! Originally, the engine was overheating and coolant was leaking. I replaced one of the hoses, water pump, and the thermostat. Now the car maintains its proper operating temperature but the heater doesn't work. Any suggestions on what might be wrong and what could be done short of replacing the heater core (I've heard you have to tear apart the entire dash to do this)? Thanks!
Saturday, February 2nd, 2008 AT 4:44 PM
BMRFIXIT
  • 19,053 POSTS
Have you tried flushing the heater core
check if both heater hoses hot if not it may need a flush
Engine cool
lower the coolant level
Locate the two hoses running to the heater core
disconnect them at the engine side leaving hoses connected to heater core throw the firewall
use garden water hose and compressed air if possible
run the water and follow by air throw one side and out the other and vice versa
do that two to three times watching what leaving the heater core you are looking for the good flow and clear water to run throw
also check if you have heater valve and if its working and if its vacuum hooked too
good luck
let me know
Saturday, February 2nd, 2008 AT 8:11 PM
