1989 Dodge Caravan check gauge light
DIGNIT
1989 Dodge Caravan 6 cyl Front Wheel Drive Automatic 163.oo miles
My check gauge light comes on sometimes. What does that mean?
Dec 12, 2009 at 12:02 PM
CH112063
  • 1,320 POSTS
If an important gauge like your temperature or oil or voltage reads abnormally, the check gauges light comes on. Its to get your attention. Its just a warning light. Make sure your fluids and all the proper readings are not off limits. If your engine is running ok, its nothing to worry about. A wire may be grounding, or a sensor may be off. Oil, coolant, and battery should be ckecked. OK?
Dec 12, 2009 at 1:54 PM
