1989 Dodge Caravan
JUST_A_LIL_BIT
Other Category problem
1989 Dodge Caravan 4 cyl Wheel Drive Type unknown Automatic ?????? miles
There is a antifreeze leak underneath the van...it is not from a hose or the rad. As soon as l put antifreeze or water in it, it leaks right out the bottom. It looks like it is a seal or gasket but l'm not sure. What would the fluid be leaking from? How do l repair it?
Jan 6, 2008 at 9:46 PM
  • 31,937 POSTS
Hi there,
you will have to get the system pressure tested and put up on a hoist so the mechanic can inspect it properly, it may be coming from the water pump or a core plug, there may be a leaking hose that you are unable to see from the top of the engine.
Mark (mhpautos)
Jan 6, 2008 at 10:57 PM
