02 dodge caravan turn signal issues
M.CONWAY3
My caravan sport with 75,000 miles and 3.3l engine indicates a left turn while lifting the lever for a right turn. The blinker indicator inside indicates a left turn at all times while attempting a right turn. This is very intermittent and am not sure if the outside lights indicate the same as the indicators on the inside.
Thanks for whoevers help
Oct 4, 2007 at 12:48 PM
BMRFIXIT
  • 19,053 POSTS
[quote:c7d6ff2616="m.conway3"]My caravan sport with 75,000 miles and 3.3l engine indicates a left turn while lifting the lever for a right turn. The blinker indicator inside indicates a left turn at all times while attempting a right turn. This is very intermittent and am not sure if the outside lights indicate the same as the indicators on the inside.
Thanks for whoevers help[/quote:c7d6ff2616]
YOU MAY NEED A SIGNAL SWITCH !
have you done any work on the lights
changed a bulb if so check for a wrong bulb
good luck
let us know
Oct 4, 2007 at 10:16 PM
