2002 Dodge Caravan Turn Signal Wrong Side
M.CONWAY3
My caravan sport with 75,000 miles and 3.3l engine indicates a left turn while lifting the lever for a right turn. The blinker indicator inside indicates a left turn at all times while attempting a right turn. This is very intermittent and am not sure if the outside lights indicate the same as the indicators on the inside.
Thanks for whoevers help
Oct 4, 2007 at 12:48 PM
BMRFIXIT
  • 19,053 POSTS
[quote:c7d6ff2616="m.conway3"]My caravan sport with 75,000 miles and 3.3l engine indicates a left turn while lifting the lever for a right turn. The blinker indicator inside indicates a left turn at all times while attempting a right turn. This is very intermittent and am not sure if the outside lights indicate the same as the indicators on the inside.
Thanks for whoevers help[/quote:c7d6ff2616]
YOU MAY NEED A SIGNAL SWITCH !
have you done any work on the lights
changed a bulb if so check for a wrong bulb
good luck
let us know
Oct 4, 2007 at 10:16 PM
Suggested Repair
Inspect the turn signal switch and, if bulbs were recently changed, verify that the correct bulbs are installed.
Conversation Summary
The owner of a 2002 Dodge Caravan reports an intermittent left-turn indication when requesting a right turn and is unsure whether the exterior lamps match the dash indicator. The expert suggests the signal switch may need replacement and recommends checking for an incorrect bulb if lighting work was recently done.
