1998 Dodge Avenger Oil Light and Clatter
SCHOONEYC
I own a 1998 Dodge Avenger Sport, 2.5L V6, with 114,000 miles.
Had the engine rebuilt on 2/8/07 and picked-up car on 2/11/07. The new rebuilt engine has 523 miles on the rebuilt motor. Here is the problem, when you turn key on (but do not start engine) the oil light comes on and stays on. Then when you crank the car it makes a clattering nosie like it is out of oil, but only for a few seconds then the light goes out and the oil pressure goes up. It does run a little rough at first then gets better as you drive. Have been told that it is because the engine does not have 1,000 miles on it yet. Is that correct or is there another problem.
Thank you for any advice.
Feb 12, 2007 at 5:12 AM
  • 75,988 POSTS
[quote:6ffcb14294="schooneyc"]I own a 1998 Dodge Avenger Sport, 2.5L V6, with 114,000 miles.
That engine is broken in at 500plus miles-better investigate on the clatter and pressure. When you burn a quart of oil less than 500 something is totally wrong with rebuild or Reman. Probably wrong undersize bearings or not hot tank properly-and should always have a new oil pump on rebuild.
500miles is the observation point.
Thank you for any advice.[/quote:6ffcb14294]
Feb 12, 2007 at 10:15 AM
Suggested Repair
Do not treat the brief startup clatter and delayed oil pressure as normal break-in. Have the recent rebuild inspected for oil pressure, incorrect bearings, improper cleaning, and oil pump condition.
Conversation Summary
The owner of a 1998 Dodge Avenger with a recently rebuilt 2.5L V6 reports that the oil light stays on with the key on, followed by a brief clatter at startup until oil pressure rises. The engine also runs roughly at first and then smooths out. An expert said more than 500 miles is sufficient break-in and advised investigating the clatter and oil pressure, suspecting rebuild issues such as wrong bearings, improper cleaning, or the oil pump.
