1996 Dodge Avenger NO Spark
1996 DODGE AVENGER
120,000 MILES • 6 CYL • 2WD • AUTOMATIC
COMPMECH
1996 Dodge Avenger has no spark. I have already done all the troubleshooting possible without an ocilliscope. I have changed the Crank pos sensor twice. understand the cam pos sensor is in intigrated in the distributor, if wrong please verify. coil checks good, rplaced th timing belt since the waterpump needed to be replaced. timing had not jumped. still no spark. PLEASE HELP
thanx
Jun 27, 2010 at 7:39 AM
CARADIODOC
  • 34,383 POSTS
Hi compmech. Welcome to the forum. Have you checked for fuel pressure? You should hear the pump run for one second right after turning the ignition switch to "run". It will not run again until the Engine Computer sees engine rotation, (cranking or running). If it doesn't run at the same time that you don't have spark, you were correct to suspect the cam and crank sensors. Both systems are powered through the automatic shutdown (ASD) relay. To determine if the relay is turning on, measure the voltage on the coil wire. I don't have a service manual handy, but on most cars that is the dark green / white stripe wire. It should have battery voltage for that first second, and again during cranking. If it is missing, pop the cover off the ASD relay, reinstall it in the socket, and watch to see if the contact flips when a helper cranks the engine.
caradiodoc
Jun 27, 2010 at 12:15 PM
COMPMECH
Aside from the stuff i mentioned there is full voltage at the distributer.
as far as the ASD I cannot locate it. the manual says its in the Power Distribution Center but I can't find it.
Jun 28, 2010 at 1:53 PM
CARADIODOC
  • 34,383 POSTS
The Power Distribution Center is a fancy name for the fuse box. Another place you can check is either of the small wires on the back of the alternator. Along with the ignition coil and fuel pump, those wires get their voltage from the ASD relay. The voltage should appear during engine cranking.
caradiodoc
Jun 28, 2010 at 6:31 PM
