89 DOgde Aries problem
LAHHAVOX
  • 5 POSTS
i have a 89 dodge aries. Its got the EFI system. First of all when i first start it up it spits and sputters. Then it levels off for a bit, when i start driving it acts like it is outa gas and is sluggish to go when i floor it. I was told that it could be the spark plugs but i changed them and it still is there. Im at loss to what the problem could be. Any help would be greatly needed.
Nov 15, 2007 at 4:03 AM
BLACKOP555
  • 10,386 POSTS
disconnect the fuel pressure regulator's vacum line, if thers gas in it replace the regulator.
Nov 15, 2007 at 4:05 AM
LAHHAVOX
  • 5 POSTS
ok exactly where is that?
Nov 15, 2007 at 4:18 AM
LAHHAVOX
  • 5 POSTS
Could there be a possibilaty that its the distrubator?
Nov 15, 2007 at 6:32 AM
BLACKOP555
  • 10,386 POSTS
there is a possibility, but i dont think so, it would be sluggish and sputtering all the time and not level off when the car is ran for a bit after start off.
fuel pressure regulator is located on the fuel rail.
Nov 15, 2007 at 9:11 AM
LAHHAVOX
  • 5 POSTS
well it does act sluggish all the time. it levels off when in idle but with a high RPM idle.
Nov 15, 2007 at 10:55 AM
BLACKOP555
  • 10,386 POSTS
try spraying starting fluid directly in throttle body before starting, if it fires right up and runs great then i would check fuel relation, if not it may be the dist, and rotor.
Nov 15, 2007 at 11:38 AM
LAHHAVOX
  • 5 POSTS
ok i sprayed the starting fluid into the fuel body then started it up. It still does the same thing.
Nov 18, 2007 at 3:38 AM
