carburetor, spark plugs, catalytic converter
1984 DODGE ARIES
105,000 MILES
TEUFELHUND77
Replaced carburetor
Replaced spark plugs
when replaced carburetor i did not put some of the tubes on the ports.
car does not accelerate very well when gas pedal is pressed
popping sound out of exhaust
have noticed some loose debris moving around in catalytic con.
Apr 19, 2013 at 9:51 AM
  • 31,937 POSTS
If the catalytic converter has started to collapse the matrix, this should be replaced first as you will not be able to fix any other tune related problem until this is done.
Apr 19, 2013 at 10:15 AM
TEUFELHUND77
Apr 19, 2013 at 10:30 AM
  • 31,937 POSTS
good luck re post if you have any further problems
Apr 19, 2013 at 2:30 PM
