Hello
Next check fuel pressure, you may have a bad fuel pressure regulator. Another thing to check is that you are getting battery voltage back at the pump, you may have high resistance in a wire or relay whick will cause the pump to run slow and not push out enogh pressure.
John
SPONSORED LINKS
Saturday, August 15th, 2009 AT 7:54 PM
