1986 Dodge Aries runs strong then just dies
TINNER_2420
Electrical problem
1986 Dodge Aries 4 cyl Front Wheel Drive Automatic
I have an 86 dodge aries that runs real strong then just dies. it started intermitenly. I can drive it for 2 days and not have a problem but then on day 3 get 5 miles down the road and it'll just die. wait 20 min and it'll start and run fine for another 10- 20 min. the problem is becoming more frequent. I've gave it a tune up(plugs wires distributer cap etc) but it still does it
Nov 28, 2009 at 2:28 PM
CH112063
  • 1,320 POSTS
On a 86 the 2.2L 4 cylinder had distributor pick-up plate and map sensor problems. If you take the distributor cap and rotor off, you'll see the pick-up plate. This was checked by grabbing its wire and moving it around. The running engine would stall out. That may be it, especially after the cap was just off. There is a small round plate that moves through this pick-up plate, it was also a problem because it loosens up.These are inside the distributor.
Dec 9, 2009 at 8:01 AM
