What can cause the distributor to go bad three times in one year replaced distributor last year what can cause them to go bad?
Jan 27, 2017 at 10:30 AM
CJ MEDEVAC
✓Experienced Mechanic
There are usually three things that go bad causing the distributor to go out. First is a good frame to engine ground strap. Next is the ignition coil has high resistance and the third is you have a diode going out in the alternator which causes AC voltage to be generated.
Here are to guides to help you see what the problem is.
