distributor to go bad?
280,000 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
DRIPPER
  • 11 POSTS
What can cause the distributor to go bad three times in one year replaced distributor last year what can cause them to go bad?
Jan 27, 2017 at 10:30 AM
CJ MEDEVAC
  • 11,000 POSTS
There are usually three things that go bad causing the distributor to go out. First is a good frame to engine ground strap. Next is the ignition coil has high resistance and the third is you have a diode going out in the alternator which causes AC voltage to be generated.
Here are to guides to help you see what the problem is.
and
Please let us know what you find.
Cheers, The Medic
Jan 27, 2017 at 11:37 AM
