Dies when idles
109,000 MILES
KYLEWELTER15
My truck is starting a little hard. Then when I give it gas, it revs up, but when it idles down it goes all the way down and dies. This was happening a couple weeks ago, found out the truck was completely missing the o2 sensor. Replaced that, ran for about a week. Is now dying again. I believe it may be the idle air control? but I am no mechanic and could use some advice. Thank you for this service very very much.
Apr 11, 2013 at 4:00 AM
HMAC300
  • 48,601 POSTS
scan for codes and check fuelpressure first. clean throttle plate on both sides with coke cleaner and iac hole
Apr 12, 2013 at 10:53 PM
KYLEWELTER15
dont know how to check fuel pressure. Cleaned throttle with choke cleaner. Wont start at all now
Apr 12, 2013 at 11:49 PM
