2004 Chevrolet Trailblazer ABS Light C0110
177,000 MILES • 4.2L • 6 CYL • 4WD • AUTOMATIC
MICHAEL POWELL
  • 20 POSTS
My ABS Light came on. And I ran scan tool but there is no current code.
In code history C0110 was present.
The brakes seem to work just as they always did. I don't notice anything wrong.
I tried to erase the code to shut the ABS light off. But it continues to come back on when I restart the car.
My transmission doesn't seem to be shifting as smoothly as it was. It was a little low on transmission fluid, so I topped it off. It shifted a little smoother but at times when I accelerate it just lags and then takes off. The shifting also is ruff most of the time still, like its slipping.
I'm wondering if this could possibly be the speed sensor because the ABS light is on? Or maybe one of transmission solenoids?
Thanks
May 9, 2023 at 5:32 AM
BRENDON S
  • 653 POSTS
Hello MICHAEL POWELL,
This code is set when the Electronic Brake Control Module or EBCM for short detects and open in the pump motor, a shorted pump motor, or a seized pump motor or ABS pump. When this happens the EBCM will disable the ABS and turn the indicator light on.
Sometimes it can also be caused by a bad Anti-Lock Brake Traction Control Module.
Is the red brake light on? Like if you had the E-Brake engaged? Any ABS activation, pulsing in pedal, at slow speeds on dry pavement?
First thing with any electrical diagnosis is to check fuses, power and grounds.
I have added a wiring diagram for you. I have circled the items I need you to look at first.
1) Check 60 AMP fuse in under hood fuse block, fuse number 33. This fuse should be big with a clear top.
I am adding a diagram of your under-hood fuse block with a legend. I have circled the fuse for the ABS.
I would also check all other fuses to see if any other circuits are out.
Here is a good article to explain the best way to do this:
Here is an article on best practices when searching for electrical issues that I think will help as well:
2) Check for power at ABS Pump. I have added a connector end view for you. You can use a test light for this. Just connect the lead to ground and use the probe end to check for the presence of power. This test should be performed with the connector disconnected.
3) The ground for this is on the outside frame rail near the body mount just behind the front driver's side tire. I will add a picture for you. This picture contains 2 grounds, but this is about the location it should be. If there is more than one just cleans them all. I recommend cleaning this ground. Use some penetrating oil for the bolt and remove the bolt slowly and carefully. Then clean the frame to bare metal and clean connector as well. Re-attach ground, prime with Etching primer and paint to prevent further corrosion. Do not use any Di-Electric Grease as this grease prevents electricity from flowing.
Here is a general article about common ABS module failure symptoms:
https://www.2carpros.com/articles/7-common-symptoms-of-a-bad-automotive-abs-module
I would disconnect battery negative, so you don't get a voltage spike when reattaching ground. A voltage spike could fry the module.
Try these few things and let me know what you find, and we can go from there.
Thank you,
Brendon
May 10, 2023 at 3:41 AM
MICHAEL POWELL
  • 20 POSTS
The red brake light is not on, fuses were good. And the power had 12.3 volts and the ground on the frame was 12.3 volts. I was also able to turn on the pump and relay with my scan tool.
May 19, 2023 at 10:55 AM
BRENDON S
  • 653 POSTS
Okay, good. let's look at a couple other things.
Disconnect the 2-wire pump connector and check for resistance across the pump motor, what do you get? Spec on the pump motor is between 0.3 ohms and 1.0 ohms.
I would also back probe the module connector on terminal A1, it's a brown wire on the module connector. You should have 12v with the key on. I will add a connector end view for you.
Any signs of connect damage, corrosion? The harness should run on the inside of the frame rail on the driver's side. Take a look and see if there are any issues especially right around where the fuel line runs over the harness.
Also, if you have freeze frame data for the code could you please take a photo of it and upload it?
Let me know what you find.
Thank you,
Brendon
May 19, 2023 at 12:15 PM
Suggested Repair
Treat C0110 as an ABS pump-motor or EBCM circuit fault, not a wheel-speed sensor or transmission solenoid. Fuses, pump power, frame ground, and scan-tool pump/relay activation already checked out. Next, measure pump-motor resistance (spec 0.3-1.0 ohms), confirm 12V at module terminal A1 (brown wire) with the key on, and inspect the driver-side frame-rail harness and connectors for damage or corrosion, especially near the fuel lines.
Conversation Summary
A 2004 Chevrolet Trailblazer owner reported an ABS light with historical code C0110, normal brake feel, and separate rough shifting after low transmission fluid. The expert explained C0110 indicates an open, shorted, or seized ABS pump motor, or a possible bad ABS/traction control module, and advised checking fuses, pump power, and the frame ground. The owner found good fuses, 12.3 volts at power and ground, and could command the pump and relay. The expert then requested pump-motor resistance, key-on voltage at module terminal A1, a harness/connector inspection, and freeze-frame data. No final repair was confirmed.
