diagnostic codes 25(air-fuel ratio lean malfunction) and 71(egr system malfunction)
1995 TOYOTA COROLLA
160,000 MILES • 1.8L • 4 CYL • FWD • AUTOMATIC
RICHARDCARSON1
  • 21 POSTS
I bought this corolla and checked diagnostic codes. 25 and 71 are what flashed. I guess my first question is: I found that the main air cleaner intake hose was way loose on the air cleaner side. Would that being so loose (the clamp was not there and hose was almost disconnected) cause these two codes to flash.
Also can you tell me, and not quoting the things from book, bcuz I don't really understand, what steps in sequence, I can perform in order to cure these two codes?
Any and all answers are so greatly appreciated. Thank you. Respectfully, Richard Carson
Jul 25, 2014 at 2:40 AM
  • 110,244 POSTS
Richard,
The two codes can be related, but the mass air flow sensor is after the air box so that wouldn't cause a lean mixture. Have you checked the engine for engine vacuum leaks? Have you checked the EGR to see if it is stuck open?
Jul 26, 2014 at 10:38 AM
