1994 Toyota Corolla
1994 TOYOTA COROLLA
138,000 MILES • 4 CYL • 2WD • AUTOMATIC
GILMARTI
I want to know whats the code 22, code 14 and code 52
Oct 16, 2010 at 2:30 PM
BLUELIGHTNIN6
  • 16,542 POSTS
CODE 14 - Ignition Signal Interrupted = Probable cause is ECM or wiring to ECM
CODE 22 - Engine Coolant Temperature Sensor Signal = Probable cause is ECT sensor, wiring to sensor or faulty ECM
CODE 52 (1.8L only) Knock Sensor Signal Interrupted = Probable cause is knock sensor, wiring or faulty ECM
Oct 16, 2010 at 4:02 PM
