Dashboard instruments do not light up
59,000 MILES • 2.0L • 6 CYL • AUTOMATIC
TONYDB5656
My dashboard is dark doesn't light up. Can't tell how fast I'm going and how much gas I have. I checked fuses they seem okay, but not sure.
Aug 6, 2019 at 1:42 AM
  • 55,865 POSTS
This is common when the headlight switch goes out. Here is how you replace it:
1. Disconnect battery ground cable, then remove upper console, if equipped.
2. Remove accessory trim plate as follows:
a. Pry steering column collar rearward, using a suitable tool, and remove.
b. Remove outer air deflectors, then the two screws behind the deflector openings.
c. Remove screw from behind steering column collar.
d. On models less console, open ashtray and remove trim plate attaching screws.
e. On models with console, remove four screws from ashtray trim cover, then ashtray trim cover. Remove trim plate attaching screws.
f. On all models, pull trim plate rearward to release clips, then remove trim plate.
3. Remove 3 switch to panel attaching screws.
4. Pull switch rearward and remove from panel.
5. Reverse procedure to install.
Aug 7, 2019 at 12:29 PM
TONYDB5656
Thank you. The car is in my garage in Florida right now I'm in New York. I will try that when I get down there.
Aug 7, 2019 at 8:07 PM
  • 55,865 POSTS
Sounds good, please let us know what you find.
Aug 8, 2019 at 3:11 AM
