dash lights went out 2 days ago no fuses are blown
1999 DODGE DAKOTA
114,000 MILES • 3.9L • 6 CYL • 2WD • AUTOMATIC
COXROBE
My son turned the truck on to come home and no dash lights were working. I checked all the fuses in fuse box and all are good. this vehicle has on occasion lost all power to gauges and will not power them up until truck is turned off and when turned back on all gauges work fine. this dash light deal is new though
Jun 5, 2014 at 10:51 AM
  • 110,244 POSTS
Since they all went out, I would make sure the connection behind the dash is tight and clean. Also, check to make sure no grounds came off. If everything looks good, the next thing I would check would be the body control module (BCM)
Jun 5, 2014 at 12:03 PM
