dash gauges
1998 FORD CONTOUR
100,000 MILES
WLEWALT
  • 12 POSTS
I just bought a 98 Contour (4 cylinder). The three gauges in the dash don't function. The fuel gauge seems to be stuck in the full position, the speedometer don't work and the temp gauge spike to the red zone immediately after turning the key on. The car is not over heating even though the gauge says it is. I replaced the thermostat today and that didn't work, then I realized that the gauge was moving to the red zone before the motor was even running. I'm stumped, I cant help but feel all three dash gauges are plaged with the same problem, I find and fix that problem and all three will function again. any suggestions?
May 8, 2013 at 11:13 AM
the cluster has failed. you will have to replace the unit
roy
May 8, 2013 at 12:09 PM
WLEWALT
  • 12 POSTS
Roy, by cluster, do you mean the entire component that holds and houses the speedometer, oil pressure gage and fuel gauge? If so, I picked one up at the salvage yard today and it did the same exact thing, which leads me to believe that that isn't the problem. Please tell me that "Cluster" is something else. thank you.
Warren
May 9, 2013 at 10:04 AM
no, that was the cluster.
i am going to check to see if you have to have it flashed. cannot interchange units from another car
roy
May 9, 2013 at 10:38 AM
WLEWALT
  • 12 POSTS
Well actually, that makes perfect sense, if it does have to be flashed, can any Ford Dealership do it, or where can I have it done?
May 9, 2013 at 10:52 AM
yes, the dealer.
May 9, 2013 at 10:58 AM
WLEWALT
  • 12 POSTS
thank you, I will give them a call tomorrow, I do appreciate it very much!
May 9, 2013 at 11:00 AM
WLEWALT
  • 12 POSTS
Ok, I went in to the dealership today and they said that it was just plug and play, no reprograming was required for that year. He did mention the ECU or something like that but told me that it would cost me 120 bucks to put it on the machine to tell me for sure. I did install another ECU and that didn't do the trick either. Other than putting it on the machine, any suggestions?
May 10, 2013 at 8:48 AM
