2000 Daewoo Leganza Engine Turnover, but no fire
JBEKHM
  • 2000 DAEWOO LEGANZA
  • 4 CYL
  • FWD
  • 65,000 MILES
My 2000 Leganza cdx has a small problem with starting. After replacing the timing belt, the engine will turnover but will not fire. I sprayed car starter in the throttle body and it seems like it is close to firing, but still no dice. A friend who is a mechanic tested the engine for compression and said all cylinders are good. Dont know what it could possibly be. The car has been sitting for about 3 months, so could the fuel system be an issue or what. I think that it at least turns over is a good sign, could it be something major if it turns over? Not the most mechanically inclined but have learned a lot reading and studying. Thanks for any help, just trying to have a car to drive.
Saturday, November 29th, 2008 AT 2:05 AM
ZACKMAN
  • 4,202 POSTS
If you sprayed the throttle body and still not firing, you can rule out fuel problem.
Do you have spark? Re-check all your timing marks and make sure that they are all lined up. Also check if the cam and crankshaft sensors are installed correctly.
Monday, December 1st, 2008 AT 11:07 PM
