2000 Daewoo Leganza STALL OF ENGINE
2000 DAEWOO LEGANZA
27,000 MILES • 4 CYL • 2WD • AUTOMATIC
VSJERRY6244
HELLO, I JUSTA MACHANIC PUT A 27000 MILE (CARFAX) IN MY DAEWOO. RUNS GREAT SOUNDS GREAT BUT SOMETIMES ON STARTUP IT STALLS AND SOMETIMES WHEN IT GETS WARM IT STALLS . THE ENGINE PUT IN WAS A 2001 TO BE INSTALLED IN A 2000 THE ONLY MODIFICATION MY MACHANIC TOLD ME WAS ONE OF THE BELTS WAS LARGER.
Aug 6, 2010 at 2:12 AM
KHLOW2008
  • 41,814 POSTS
Hi VsJerry6244,
Thank you for the donation.
Is the Check Engine Light indicating?
Have you tried to retrieve for trouble codes?
Aug 6, 2010 at 4:07 AM
VSJERRY6244
[quote:e6005c7710="KHLow2008"]Hi VsJerry6244,
Have you tried to retrieve for trouble codes?[/quote:e6005c7710]
THE ENGINE LIGHT CAME ON ON INSTALATION OF THE ENGINE BUT THE READ WAS SOMETHING TO DO EXAUST SYSTEM OR A LOOSE GAS CAP. AFTER BEING PUT ON CMPUTER FOR THE CODES THE LIGHT WENT OUT 4 WEEKS AGO AND NEVER CAME BACK ON.
Aug 6, 2010 at 4:18 AM
KHLOW2008
  • 41,814 POSTS
If the CEL does not come on, then the problem should be due to the idling system.
Get the throttle body and Idle Air Control valve cleaned and retest.
Aug 6, 2010 at 5:59 AM
