2000 Daewoo Leganza my daewoo wont even crank?
2000 DAEWOO LEGANZA
11,500 MILES • 4 CYL • 2WD • AUTOMATIC
EVANLAPLANTE
  • 16 POSTS
i have a 2000 daewoo laganza and have never had any problems with it the other day my mother drove it and she kept calling me saying that it was dying at every stop sign well finally the fifth stop sign it would not start again so i had it towed home my mother said it was a little shaky and smelled like burning wires i thought maybe it was the starter cause all it does is make a small clicking noise when i try to start it no crank but had the starter tested and its good so please help me
Feb 15, 2009 at 5:23 AM
Test the battery make sure its good and the connection if okay could be the a starter relay, park/neutral switch and ignition switch
Feb 15, 2009 at 5:33 AM
BOBBYTECH1
  • 49 POSTS
dont try to start teh car because chances are ur number 4 cylinder could be full of coolant since its a common problem with them , just remove #4 plug and see in side the hole to see if its full of coolant ..try to get back to me
Feb 16, 2009 at 1:33 AM
This name Bobbytech1 sounds familiar-take this thread and keep me posted its very busy now a days-Good Luck. BTW I got your PM and saved Thanks!
Feb 16, 2009 at 4:16 AM
EVANLAPLANTE
  • 16 POSTS
the batter is good and so is the connection saftery nutral switch is good no coolant in #4 spark plug wires and plugs llok good replaced the relay switches still noting just click click
Mar 8, 2009 at 11:13 AM
Check fuse no.5 30amp, park and neutral relay, starter and ignition switch. Do this have helper hold key at start position and check for power at the park and neutral switch orange and black wire-Do you have it?
https://images.2carpros.com/forum/automotive_pictures/12900_daewoo_2.jpg
Mar 8, 2009 at 11:22 AM
EVANLAPLANTE
  • 16 POSTS
my brothers said its all in good working order relays and switches and the fuses ahhhh this sucks lol
Mar 8, 2009 at 11:35 AM
Fuses/Relays are up to snuff do below
Tell him to direct battery power to the fuel pump and see what happens
Mar 8, 2009 at 11:38 AM
EVANLAPLANTE
  • 16 POSTS
he said the fuel pump turned on
Mar 8, 2009 at 11:47 AM
EVANLAPLANTE
  • 16 POSTS
and he also says that the engine is definatly not seized
Mar 8, 2009 at 12:41 PM
Check the fuel pressure and comeback with the readings
Mar 8, 2009 at 2:21 PM
EVANLAPLANTE
  • 16 POSTS
how do i check fuel presure and woudnt the engine at least try to turn over even if there was no fuel?
Mar 8, 2009 at 3:53 PM
Is this vehicle cranking over and refusing to start
Do below and tell me what's going on.
Disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,distributor pick-up coil, ignition control module, cam and crank sensors- Note: If it doesn't apply disregard it
Mar 8, 2009 at 8:05 PM
EVANLAPLANTE
  • 16 POSTS
no the engine doesnt crank at all
Mar 9, 2009 at 9:58 AM
Load test the battery double check all connections and also test the following starter, starter relay, park and neutral switch and ignition switch. If you have a security system have that check too and comeback with some results before we continue
Mar 9, 2009 at 10:02 AM
