2017 Ford Explorer CHT Sensor Location Fix
Suggested Repair
Access the sensor behind the turbo shielding: remove the plastic cover and airbox pipe to the turbo, remove the two shield nuts, move the solenoid aside, disconnect the crankcase breather, and move the turbo inlet out of the way. The sensor is screwed into the manifold. Disconnect and replace it (not reusable), torque the new sensor to 97 inch-pounds, and reassemble in reverse.
Conversation Summary
The owner of a 2017 Ford Explorer 2.3L EcoBoost asked where the cylinder head temperature (CHT) sensor is located. The expert said it is buried behind the turbo shielding and gave access steps: remove the plastic cover and turbo airbox pipe, remove the two shield nuts, move the solenoid, disconnect the crankcase breather, and move the turbo inlet aside. Looking down toward the manifold, the sensor is screwed in. It should be disconnected, discarded because it is not reusable, and replaced at 97 inch-pounds, then the parts reassembled.
