Cranks will not start
148,000 MILES • 3.7L • 2WD • AUTOMATIC
TRUESS77
I drove on a very bumpy road and was very low on fuel. while driving the car lost power and i coasted to a stop on side of road after which the car didn't start. i added fuel to the tank and it still didn't start. had car towed home. i bought a new battery, no start. replaced the TPS, no start. I even replaced the PCM and it won't start. please help
May 26, 2020 at 5:40 AM
Good evening,
Can you hear the fuel pump come on when you turn the key to on? I would check the fuel pressure. Running out of fuel ruins the fuel pump as the fuel is a lubricant as well as a coolant for the pump.
Can you see an RPM signal on the dash when you crank it? That will tell me if the crank sensor is working.
I would also do a compression test as well.
May 26, 2020 at 8:09 AM
