Cranks no start
200,000 MILES • 5.0L
YNOT ME
Replaced ignition module and stator getting fire to distributor to plugs .sprayed starting flued to throdel no start.
Oct 31, 2020 at 5:27 AM
  • 110,248 POSTS
If you are getting spark to the plugs, it should start for a couple seconds (at least) using starting fluid. Is the spark at the plugs a good hot blue snapping spark?
Also, have you checked for fuel to the engine?
Here are three links. The first discusses the most common causes for a crank no start condition. The next two are for testing spark and fuel.
Let me know if you checked for diagnostic trouble codes. This truck has an OBD1 system. It doesn't require a scan tool. Here is a link that shows how it is done:
https://www.2carpros.com/articles/ford-lincoln-mercury-obd1-1995-and-earlier-diagnostic-trouble-code-definition-and-retrieval
May 31, 2021 at 5:47 AM
