Engine cranks over but will not start?
26,000 MILES • 4.0L • V6 • 2WD • AUTOMATIC
TOMDERWOODS
  • 29 POSTS
When ever it decides, it just cranks. Fuel pressure 66 lbs. 12.86 volts at fuel pump. New fuel inertia switch. Put in spare at second no start to be sure. Sprayed start fluid first time, started. second time no. Five minutes later fired right up, run ever since. Sprayed in after MAF sensor. More than ten trips three hundred miles runs great. Waiting for a no start to verify spark. Starting out was inertia switch, that was reason for suspecting no fuel. And with either starting it first time. Also, no codes. Also measured starting voltages. 12.88 static, 10 40 cranking, 14 01 running.
Apr 25, 2019 at 7:26 PM
Good morning, No to the inertia switch. If it was bad, you would have had no fuel pressure. When you turn the key to the on position without cranking the engine over can you hear the fuel pump run in the tank for 5 seconds?
Please run down this guide and report back.This sounds like a spark issue. Let me get you a diagram for the ignition system. Roy
Mar 2, 2021 at 3:25 AM
TOMDERWOODS
  • 29 POSTS
Okay. Diagrams will be helpful, but there are a lot of possibilities. Can we narrow it down to what usually fails and how to test it. Say, can it be CPS, MAF?
Do you have battery voltage to the connector for the coil?
When you crank it, does the tachometer move up a little?
TOMDERWOODS
  • 29 POSTS
Good things to check when it happens. The tachometer movement indicates CPS working, correct? Right now problem is, it runs great 300 plus miles and 10 trips. No problem. That is my problem. Cannot depend on it and take wife out on it. May need towed. That is why I was looking for something that may cause it and how to test it. Thank you Roy!
You are welcome.
Always glad to help.
TOMDERWOODS
  • 29 POSTS
Is there anything else that may be failing, intermittent, that you would check?
TOMDERWOODS
  • 29 POSTS
If I don't have voltage at coil, where do I check next?
Follow the diagram with the wire I highlighted. Go to the source and check for voltage. I believe it is a common feed from the ignition switch.
TOMDERWOODS
  • 29 POSTS
Okay on wire. I removed fuel pump relay. Tachometer bounces up and down while cranking.
TOMDERWOODS
  • 29 POSTS
Can it be the fuel pressure regulator sticking? Pressure does bleed to zero over night. Starts right up, but if it sits for five days, it cranks more to start. I added injector cleaner, so far no change.
Why did you remove the fuel pump relay?
Yes that says the crank sensor is sending a signal.
Most likely the check valve in the pump is the reason for drain back.
TOMDERWOODS
  • 29 POSTS
I removed to simulate a no start condition. Otherwise it just starts right up. So one down, other than heat. Should I hear up CPS and see if it fails. Ambient temperature was 70 last no start. Had sit for 15 to 20 minutes. Can the pressure reg hanging open like would be at idle cause no start?
TOMDERWOODS
  • 29 POSTS
I don't get any backfiring or slow acceleration. Runs normal.
Mar 2, 2021 at 3:26 AM
TOMDERWOODS
  • 29 POSTS
Also, dealer says factory alarm will not cause my no start because if it was problem, engine would not crank. True?
Yes, that is true.
TOMDERWOODS
  • 29 POSTS
Okay, it quit. After doing CPS test and started afterwards, I closed hood. Now won't start. Yeah! I had added a light bulb to where inertia switch plugs in so I could observe cycle. Short light for short pump run when first turn key on. Then lights constant on while running. After closing hood, I get no light, even when started for short time to run fuel out of rail. Measured volts at inertia sw. Get 12.30 momentary on DG/YE power wire. Then it drops to 6.83v. Any ideas?
TOMDERWOODS
  • 29 POSTS
My light, I used old sw to use plug in so I didn't cut wires. Soldered across contacts.
That voltage comes from the relay.
TOMDERWOODS
  • 29 POSTS
Okay, now it starts again. Only at inertia sw plug. With meter on, I get 12.5 volts while short light, then hoes to zero. Unlike no start, 6.83. Then running I get 13.65v.
TOMDERWOODS
  • 29 POSTS
Okay. But why the low voltage constant? And I swapped relay before.
TOMDERWOODS
  • 29 POSTS
Okay. With light connected, same as sw plugged in, it gives me 12.5v then goes to zero. With sw out of circuit, unplugged relay zero goes to 6.92v. Should be zero if relay is only connection to wire.
The pump should run for two seconds. Then full when cranking and running.
Yes it should be 0. At 6 it will run the pump.
TOMDERWOODS
  • 29 POSTS
Exactly! I agree. If relay is good, I swapped all 4 into fuel pump position, then it can only be one thing. Connectors at inertia sw plug. The 6.83 volts is at the relay contacts that goes to the cpu pin 40. So I would say floating voltage. You? As I understand, cpu mostly connects the ground circuits. True?
Correct.
TOMDERWOODS
  • 29 POSTS
Thank you for all the help and talking it out with me and the patience. I will chase out the wires and connectors and get back to you with results. Will be good to resolve this issue.
You are welcome.
TOMDERWOODS
  • 29 POSTS
Okay, wires all ohm out good. Getting 12.5v to relay coil. Ground to relay coil good. All comes back to connectors at inertia sw. If I have running and move wires around on back of plug, it quits. Going to get tool to remove pins from plug. Has to be bad crimp. Makes since. While idle, it will run for four seconds after disconnecting. So on a rough road or bump, it has four seconds to reconnect. Will let you know.
Keep us updated.
TOMDERWOODS
  • 29 POSTS
The connector is under dash so hard to see good Took pics of to find one and the female end is all black. Does not look good. That is the bad connection. Must of not been tight, overheated and carboned up. Located a Dorman at Amazon, same at Autozone and O'Reilly but $10 cheaper. Cutting off old connector. Tie those 2 wires plus one for my light so I can drive and monitor. Want to be sure it is fixed before I put switch back into circuit. Then will connect new connector and put all back normal. Thank you for all your help Roy! I appreciate your responses and guidance.
TOMDERWOODS
  • 29 POSTS
And to help, here are pics.
TOMDERWOODS
  • 29 POSTS
Good luck all.
That is the correct pigtail. I would replace the inertia switch as well.
TOMDERWOODS
  • 29 POSTS
Good idea! Thank you!
Your welcome
TOMDERWOODS
  • 29 POSTS
Hi Roy! Update: have been driving it. Made five plus trips. Working great. I took old plug apart. Crimp was good. Has to be loose fitting connection which would account for wire being warm to the touch before. Wire now normal temperature. Still have light on it for monitoring the proper sequence. Waiting for new connector.
Your website is fantastic. So glad to have the knowledgeable resource.
Thank you for the kind words.
We are always glad to help.
TOMDERWOODS
  • 29 POSTS
Okay. New connector. Dealer did warranty on inertia switch all new, works great. It was s bad wire connection in connector. About 600 miles. No problems. Wired in 12v light on pump side for monitoring.
Good deal.
TOMDERWOODS
  • 29 POSTS
Hi Roy! I have driven the 04 Ranger 4.0 all summer and no troubles. Then Oct 6th, no start. My test light was normal sequence, light on for 2 seconds, then constant when cranking. Tack was bouncing and it would run like 200rpm stumbling along every time I tried it. In parking lot, could not hear pump. After waiting about 30 minutes, started right up. Got home. Off on off on, started fine. Fuel pressure 65psi. Then Nov 5th, same thing, only I had fuel pressure gauge with me. I had 10 to 12 psi while cranking. Light normal. Tried fuel cap off, could not hear pump. Noisey. Waited 30 minutes, Key on had 65psi, started right up. Now what. Only 85 degrees outside. Coming home waited in mile long stop and go traffic. Before no start, traffic moving normal. What i s your thoughts Roy?
