Cranks but will not start?
286,750 MILES • 1.4L • 4 CYL • 2WD • MANUAL
KRISTYDESTROYER
Getting fuel but won't start, carb maybe bad, we have added new fuel, new battery.
Feb 25, 2023 at 4:48 AM
  • 110,248 POSTS
In most cases, a crank no start condition is caused by either a lack of fuel or a loss of ignition spark at the spark plugs.
I need you to try something. See if it starts if you use starting fluid. If it does and then stalls, we know it is a fuel-related issue. If there is no change, we need to check for an ignition spark at the plugs.
Here is a link that explains how to do it:
https://www.2carpros.com/articles/how-to-check-for-ignition-spark
Try this and let me know the results.
Feb 25, 2023 at 3:03 PM
