Cranks but will not start
54,000 MILES • 4 CYL • 2WD • AUTOMATIC
JIMAR KUSH SKYHIGH
Good day guys, my car cranks but will not start. also, it shut off on me a couple of times on the highway and would not start until a significant amount of time had passed. i changed the distributor and plug wires on it and the problem is still there. can i get some assistance on what could be the problem please?
Apr 12, 2018 at 2:12 AM
  • 31,937 POSTS
Is this a carburetor or injected engine model?
Apr 12, 2018 at 5:44 PM
JIMAR KUSH SKYHIGH
injected.
Apr 13, 2018 at 7:30 AM
  • 31,937 POSTS
check for codes, now remember that not all codes will set a check light, have you been able to re test for spark when it fails, you may have an ignition module over heating and shutting down.
Apr 13, 2018 at 11:17 PM
JIMAR KUSH SKYHIGH
I am not getting any spark through the plug wires, but there is current leading up to the distributor.
Apr 16, 2018 at 12:44 AM
  • 31,937 POSTS
Probably a failed ignition module, it is internal of the of the distributor. so a second hand distributor should be a quick fix.
Apr 17, 2018 at 9:12 PM
