Crank position sensor
158,000 MILES
RIPLEY RADAROOM
This is a B250 ,1990 ,318.
I was told it does not have a crank position sensor but the store says it does.
Cannot find it. I was told I would have to replace it after replacing the pick up coil.
I did MAP, I did Thermo temperature sensor and still it cuts off sometimes at a stop.
Especially after I disconnect the battery and reinstall.
How could this one year not have a crank position sensor? And it is not in the distributor as some one here said. That would be the camshaft sensor.
What is the deal ? Help ?
Mar 26, 2018 at 9:16 AM
HARRY P
  • 2,292 POSTS
There is no CPS according to Prodemand. There is a crank angle sensor that is mounted on the bellhousing of the transmission, which is probably what the parts store people are pulling up.
Mar 26, 2018 at 12:16 PM
