Crank No Start
130,000 MILES • 2.2L • 4 CYL • MANUAL
AVENEY18
Prior to my current issue, I had my fuel pump replaced. A few days later while driving, when slowing down or stopping the car would shut off. I would crank it and it would either start immediately or crank briefly before starting. While stopped if I didn't put the car in gear n press gas and clutch it would die, jerking, trying to stay "alive". The last time I drove it when I pulled into the driveway it died again. Tried starting and now just cranks and no start. I have replaced the spark plugs, and the crankshaft sensor. Still nothing. I bought a new starter but was told it wasn't the starter. So we are still back at square one. Tested the battery and it is fine. Any help, please?
Jan 16, 2016 at 4:12 PM
I would start with checking fuel pressure. you can rent a tester at a parts store to verify
Jan 16, 2016 at 6:06 PM
AVENEY18
Checked the gas pressure, it's fine. Changed out the crankshaft sensor, spark plugs, timing chain, ECM. Had the alternator checked. Still will not start.
Feb 1, 2016 at 6:18 AM
