Crank no start?
196,000 MILES • 2.0L • 4 CYL • 2WD • MANUAL
SEWELLB303
I just installed a new motor in my vehicle, and I tried to crank it, it will crank but does not start up. While trying to crank it it's making a whining noise. what could be my problem?
Oct 14, 2022 at 12:25 AM
  • 110,248 POSTS
In most cases, a crank no start condition is caused either by no spark to the plugs or a fuel-related issue. However, the noise you indicated has me concerned.
Is it possible for you to record and upload it for me to hear?
Let me know. Also, if you want, see if it starts for a couple of seconds using starting fluid. If it does and then stalls, we know it's fuel related. If there is no change, check for spark to the plugs.
Here is a link that explains how to do it:
Oct 14, 2022 at 3:54 PM
