Crank no start
279,000 MILES • 4 CYL • 4WD • AUTOMATIC
SARAGREER
I have a vehicle that seems to have many problems. The biggest problem I have right now is that it will crank but not fire. I have check everything I can think of. Replaced the plugs. Checked the fuel rail it has gas. I hear the fuel pump when I turn it to the on position. It does have an overheat issue but I do not think that is related because that has been an on going battle. I am at a loss as to where to look next.
Jan 21, 2018 at 4:38 AM
KHLOW2008
  • 41,812 POSTS
Certain criteria must be met before an engine can be cranked started. The link below should be helpful to you. Go through and let us know if you require further assistance on this.
Jan 21, 2018 at 2:04 PM
