car has not been started in about 10 months?
153,000 MILES • 1.3L • 2WD • MANUAL
XSOCIALDECAYX
This car was parked about 1 year ago after it was hydroplaned and began to overheat when started.
The previous owner started the car regularly then stopped doing that so the car has not been started in about 10 months now.
I bought the car knowing it would not start and have since replaced the battery, starter, eccentric shaft position sensor, spark plugs, spark plug wires. I have also done an oil change as the pervious owner had full-synthetic oil in it and also drained the coolant system to put coolant in it as the previous owner had put water in it and not coolant.
I tried the de-flood process while the spark plugs were out and it would not start after that still. OBD says spark adv. is 9 which I believe to be low. I pulled the fuel lines to verify the car is receiving fuel and I believe the car is getting air.
The car will turn over but will not fully crank and run, there was a code for a rear O2 sensor and for the ABS system but i do not believe these would cause the crank no start issue. I believe the issue to be low compression or need new ignition coils as all of the other fuses and relays are good and the car does receive power and all the lights will come on when the key is is the ignition.
Mar 20, 2025 at 12:05 AM
  • 55,711 POSTS
It seems like the engine might have low compression but these engines respond well to starting fluid which I would give a try.
Here is a video to help see what I am talking about:
https://www.youtube.com/watch?v=lXLJbuAZ4CE
Here is a guide to help with the compression test to confirm:
Minimum acceptable:
6.0 kg/cm2 or
85 psi per rotor face, adjusted
Please go over these guides and get back to us.
Mar 21, 2025 at 3:57 AM
XSOCIALDECAYX
I have previously tried starting fluid. I tried it last before replacing the plugs and plug wires. I was trying to crank the car while someone was spraying small bursts of fluid into the air intake hose and the car didn't start but did start to "catch" like it was trying to start. I have also heard I can try to put some oil into the rotor housings either from the spark plug holes or from the oil filler tube as there's a hose that goes to the access ports on the other side of the engine.
Mar 21, 2025 at 4:23 AM
  • 55,711 POSTS
I would do the compression test before you go any further.
Mar 22, 2025 at 3:44 AM
XSOCIALDECAYX
Since it’s a rotary wouldn’t I need a rotary specific compression tester? I’ve found a video on how to do the test with a standard compression tester but there’s a lot of math that goes into that one.
Mar 22, 2025 at 4:07 AM
  • 55,711 POSTS
You can use a regular gauge set which you can rent form the auto parts store for cheep o free. We just need to see if the engine has any, you will know. With the gauge attached turn the engine over for a few seconds and check the reading. I would use the bottom plug.
Mar 23, 2025 at 2:25 AM
