crank case sensor removal
2003 MERCEDES BENZ ML500
108,000 MILES
MISSALLMAN
Thank you for your video on how to change this sensor. Very good.
We have the 8e bolt out but am unable to lift the sensor out of the block. Tried WD-40 and acetone. Afraid of breaking inside a block..
We thought of grinding off a 9/16 open end wrench and placing on top rectangular portion of sensor, but afraid of breaking sensor.
What do you suggest??
Mar 2, 2020 at 11:17 PM
Unfortunately there are no tricks that are sure to work. These sensors when in the engine for an extended time get the rubber seal melted to the case. This means they are stuck pretty good. The best thing I have found is you need to start by twisting the sensor so that you at least break the seal. At that point if you cannot wiggle it out then you will need to use a flat head screw driver to try and pry it up to get it started coming out.
I understand you don't want to break it but as long as you don't break it off flush to the case you should still be able to use some vise grips to grab a hold of it and pull it out. So that means you can crack the plastic and that is okay.
While it was not on this vehicle, I have had my fair share of fights with this issue and destroyed some sensors before finally getting them out.
Long story short, don't worry about being aggressive with it because you are not going to damage the engine only the sensor and you are replacing that.
Hopefully this helps.
Mar 3, 2020 at 7:56 AM
