CRANK BuT NO START
180,000 MILES • 2.8L • V6 • FWD • MANUAL
RICHTERJUSTIN08
I have replaced the fuel pump brand new which is now cutting on. Fuel pump relay is clicking when the key is turned on . Also I have spark on number one spark plug when I crank it . The first panel on the driver side door I have checked all the fuses with a fuse checker and they all light up. Need help Please help!
Cannot figure out what is wrong and why she wont start.
Jul 31, 2016 at 7:32 AM
RIVERMIKERAT
  • 6,106 POSTS
Have you scanned it for codes? Is the ignition timing set correctly? You may need to pull the timing cover off and check to see if the timing belt/chain has slipped.
Aug 1, 2016 at 3:05 AM
RIVERMIKERAT
  • 6,106 POSTS
Another thing to check would be compression.
RENEE L
  • 1,260 POSTS
Hello RICHTERJUSTIN08,
If you decide you would like to conduct the scan yourself here is a link to an article that features written step by step instructions and pictures explaining how to do the scan yourself, also I have included a link to our YouTube channel with a how to video on code scanning. Most scanners are inexpensive to purchase, you can purchase one online from sites like Amazon.com
https://youtu.be/YV3TRZwer8k
Once you have the codes please get back to us so that we can further assist you. We are always happy to help.
Thank you for visiting 2CarPros.com.
All the best,
Renee
Admin
Aug 1, 2016 at 4:52 AM
