Hello, I'm Danny.
Nope, not a dumb question. Basically, Whenever you turn on the A/C the (small-secondary) fan will continuously run to pull air flow through the radiator/condenser assembly for airflow to cool your car(radiator) and the A/C condenser for the A/C function. The Primary fan will operate when a high temperature condition is detected in conjunction with the secondary or high heat weather conditions, Engine overheating, etc. Yes, Both fans can and will possibly run together or independent. Hope this helps and thanks for using 2CarPros.
Danny-
SPONSORED LINKS
Tuesday, August 13th, 2019 AT 11:05 PM
