Engine Cooling problem
1990 Honda Accord 4 cyl Front Wheel Drive Automatic
a friend of mine has a radiator fan that runs even while the car is off.
any ideas as to what might be the problem?
Saturday, July 12th, 2008 AT 9:19 PM
BLACKOP555
MECHANIC
Should run a little bit after it is off but not all the time, most likely cause is a sticking relay or a faulty coolant temperature SWITCH not sending unit, ground the switch out, fan still run the relay is sticking.
