Cooling fan
DAVEPR86
The cooling fan in my '98 Accord is broken, probably the motor. Every junkyard I've called is asking for $100 for a used one. One junkyard I called is a U-pull it so they're charging $25 for one. The only problem is that the newest one they have is from a '95 accord. Will a cooling fan from a '95 accord fit a '98 accord, or do I need to compare the two and see if there's a difference? Thanks.
Jun 18, 2007 at 9:42 AM
MIKE H R
  • 3,094 POSTS
They should be about the same. Check the dimensions on the one that is one the car {long and high and depth} mark down the dimensions along with the description iof the connecting socket. When you go to the pull it yourself junkyard take the dimensions with you most junkyards have a cross reference and can tell if it will exactly fit.
Jun 18, 2007 at 9:57 AM
