Coolant leak?
190,000 MILES • 0.7L • 3 CYL • 4WD • AUTOMATIC
SHEIKA
I have a coolant leak on the right side of my car. I think it's coming from the intake.
May 4, 2024 at 10:27 AM
  • 110,248 POSTS
If possible, take a few pictures showing where you see it coming from.
If you can't do that, the best way to find the leak is by using a pressure tester, which is very easy.
Here is a link that explains how it is done:
https://www.2carpros.com/articles/radiator-pressure-test
This test is done on a cold engine which gives you the chance to locate the leak without being burned. You will need the pressure tester. If you don't have one, most parts stores will lend one to you.
Let me know if this helps. Also, a few pics may help me identify possibilities.
May 5, 2024 at 1:03 PM
