2017 GMC Acadia Coolant Gauge Cold
149,075 MILES • 2.5L • 4 CYL • 2WD • AUTOMATIC
CHABEL
Temperature gauge shows cold all the time, has a message saying steering assist reduced, and checking online it looks like I need to replace sensor, but need to find location and possible diagram for it, it is a 2.5 engine.
Mar 20, 2025 at 12:01 PM
  • 55,766 POSTS
You might have a thermostat that is stuck open FYI. Here is the location of the engine coolant temperature sensor which is near the top of the engine in the front where the cooling hoses converge. Check out the images (below). Please let us know what happens.
Mar 21, 2025 at 4:50 AM
Suggested Repair
Locate the engine coolant temperature sensor near the top front of the engine where the cooling hoses converge. Also check whether the thermostat is stuck open, which can keep the temperature gauge reading cold.
Conversation Summary
The owner of a 2017 GMC Acadia with a 2.5 engine reports that the temperature gauge stays cold and a steering assist reduced message appears. They want the coolant temperature sensor location. The expert says a thermostat stuck open is possible and locates the sensor near the top front of the engine where the cooling hoses meet.
