Coolant temperature light comes on
198,000 MILES • 5.6L • V8 • 2WD • AUTOMATIC
ok, the best thing to do is to take it to a parts store and have them do a load test on the battery. that will tell you if the battery is shorted. when they do it, tell me the results or get a print out
Apr 5, 2018 at 5:16 AM
MORRIFIC
  • 27 POSTS
Roy : Just got the load test done and here's the result of the print out : BATTERY TEST good battery volts 12.65v ,measured 881CCA ,rating 730CCA, STARTER TEST, normal, volts 11.36v CHARGING TEST , OK , volts 14.62v
Apr 5, 2018 at 7:02 AM
ok,
something is draining it but not all the time. tough one to diag from here.
Apr 5, 2018 at 7:04 AM
MORRIFIC
  • 27 POSTS
OK. every one I talk to about it , just told me to keep an eye on it , as it may happen again.
Apr 5, 2018 at 7:17 AM
Yep. it hard to fix something that is not broke. it needs to be more consistent to track it down.
Apr 5, 2018 at 7:18 AM
MORRIFIC
  • 27 POSTS
So thanks for everything for now and if something happens , I will get back to you . Thanks again and have a good evening.
Apr 5, 2018 at 7:52 AM
your welcome.
you as well
Apr 5, 2018 at 8:02 AM
