Coolant Smell but no visible leak
150,000 MILES • 3.8L • 6 CYL • FWD • AUTOMATIC
UPMM019
  • 217 POSTS
So this car has a smell of coolant leak but there is no visible leak found. Last checked the coolant level was down quite a bit confirming a leak. I filled the coolant and a few days later checked and the level and it was not down by much but still the coolant smell. This car has had the bypass fixed before but not replaced with the aluminum versions. I am thinking this is the issue but not sure so seeking additional thoughts.
Feb 23, 2016 at 11:49 PM
WRENCHTECH
  • 20,760 POSTS
You definitely have a leak that has to be found. Have the system pressure tested to locate the leak.
Feb 24, 2016 at 12:32 AM
UPMM019
  • 217 POSTS
Can you advise what I'd need to test it myself? I.e. a tool of some sort off of Amazon? will the test damage or worsen the leak?
Feb 24, 2016 at 1:35 AM
WRENCHTECH
  • 20,760 POSTS
Cooling system pressure tester with an adapter for your car..
Feb 24, 2016 at 1:39 AM
