Coolant leaking from between engine and fire wall
215,000 MILES • 4.0L • V6 • 4WD • AUTOMATIC
DJJONES
  • 14 POSTS
I have had the truck for a while and my wife has abused the heck out of it by not keeping up with maintinance when i ask her, Lately it had 2 coolant leaks the firt was a thermastat cover leak the second was a fill tank hose was being rubbed by the belts and it cut a hole in it, i fixed all these and now the coolant is leaking from behind the engine as soon as you pour coolant in it poors right back out. is this a head gasket leak or is it a hole in the block?
May 9, 2014 at 4:46 PM
WRENCHTECH
  • 20,760 POSTS
That could be a number of things and will require closer examination. That coulsd be anything from heater hoses, heater core, intake manifold gasket to a freeze plug in the back of the engine.
May 9, 2014 at 9:48 PM
DJJONES
  • 14 POSTS
How hard is it to seal a freeze plug leak and what do i need to do it myself
May 13, 2014 at 7:47 AM
WRENCHTECH
  • 20,760 POSTS
If a freeze plugs rots out, it has to be replaced with a new one. It's a $2 part but the cost totally depends on which one and how accessible it is. Sometimes the engine or transmission has to be removed just to get access to change it. Another issue is that if one freeze plug rots out, you can bet the others aren't far behind.
May 13, 2014 at 7:56 AM
DJJONES
  • 14 POSTS
do you have a diagram of the engine showing the freeze plugs?
May 13, 2014 at 9:51 AM
WRENCHTECH
  • 20,760 POSTS
There are dozens of freeze plugs over the entire engine on all sides
May 13, 2014 at 10:23 AM
