Coolant leaking on bottom by transmission?
239,000 MILES • 3.7L • V6 • 2WD • AUTOMATIC
JENNIFERHAVARD
Coolant leaking on bottom by transmission and engine bolt up.
Jul 29, 2022 at 9:50 AM
  • 110,248 POSTS
If you are seeing it there, chances are it is coming from one of the heater hoses. They attach the firewall to the core.
Take a look through this link. It explains how to locate and repair a leak. Let me know if this helps. If you are still unable to find it, let me know.
https://www.2carpros.com/articles/car-is-leaking-coolant
Also, if you are not able to locate the leak, you may want to pressure test the system when it's cold. That will cause the leak to occur and give you a chance to locate it without dealing with a hot engine.
Here is a link that explains how it's done:
https://www.2carpros.com/articles/radiator-pressure-test
You will need a pressure gauge set, but most parts stores will lend one to you.
Let me know what you find.
Jul 29, 2022 at 3:27 PM
