Coolant leaking from the side of the radiator?
2003 DODGE DURANGO
180,000 MILES • 4.7L • V8 • 2WD • AUTOMATIC
MYRANDA85!
October of last year i replace the radiator and water pump. Now it looks like there is coolant leaking from the side of the radiator. I can't really tell where it's coming from. I've added about a half a gallon in the last week so it's not a really bad leak but it's a little. Should I get a new radiator or just pour the aluminum sealant in?
Jul 28, 2022 at 3:12 AM
  • 110,244 POSTS
We need to determine if it is the radiator, a faulty hose, or even a simple clamp. Also, aluminum sealants can cause restrictions in other areas. I never use it.
Do me a favor. Take a look through this link and let me know if it helps you confirm the location of the leak:
https://www.2carpros.com/articles/car-is-leaking-coolant
If you are unable to locate the leak, the system will need pressure tested. You will need a pressure tester, but most parts stores will lend one to you.
https://www.2carpros.com/articles/radiator-pressure-test
I'm recommending this because the radiator isn't an inexpensive repair. If it is the radiator and you installed it only a year ago, see if there is any warranty on it as well.
Let me know what I can do to help.
Jul 28, 2022 at 7:01 AM
