Coolant boils out reservoir if Idling for twenty minutes
150,000 MILES • 1.6L • 4 CYL • 2WD • AUTOMATIC
PANMIKE
  • 31 POSTS
Stopped for my wife to complete some forms at a government facility and after twenty minutes with the air conditioner on in the sun the car boils over from the reservoir plastic white tank. This happens almost every year. Have tried engine block stop leak and seemed to work for about two years.
Apr 2, 2018 at 4:01 AM
KHLOW2008
  • 41,812 POSTS
First thing you need to check is the cooling fans. Are they working correctly?
Next is radiator cap, it could be weak. Stop leak does not solve overheating problems, they only assist in stopping minor leaks. When coolant is depleted, overheating would occur. Do you have coolant losses issues?
The radiator, water pump and thermostat are other components you need to check/test for fault.
Apr 2, 2018 at 6:48 PM
PANMIKE
  • 31 POSTS
The coolant is full, new, and not dirty. The two fans, one for the radiator and one for the A/C condenser in front of the radiator are working. The sensor is new or close one year old, fuses checked and changed a month ago. All appears to be working normally. It boils out the white reservoir tank after sitting idling for thirty minutes.
Apr 3, 2018 at 3:52 AM
  • 55,688 POSTS
Yep sounds like a blown head gasket we can firm the failure by following this guide.
Cheers, Ken
Apr 5, 2018 at 8:43 AM
